2008 F-250 Lariat Supercab
Year: 2008
Make: Ford
Model: F-250
Price: $17500
Mileage: 129000
Color: Black
Private or Dealer Listing: Private Listing
Location (State): WI
Transmission: Manual
Drivetrain: 4WD & AWD
Color: Beige
Engine: 6.4L Diesel
Black Exterior/Tan Leather
6.4L Diesel
129K Miles
Clean title and car history please ask for VIN to run carfax.
6 Speed Manual with Southbend Dual Disc Clutch (Please do your research on these clutches) This is a heavy duty clutch designed for towing.
Standard 6 speed trans, manual 4X4, factory manual lockout hubs
Factory Trailer Brake Controller
I bought this truck from a diesel mechanic and it has been very good to me since. It has a dpf delete/ SCT tuner livewire/S&B Cold Air; I have had absolutely no problems with this setup. I do have the DPF and factory air box to be put back to stock. The truck also has rear air bags installed on the leaf springs.
Amsoil synthetics have been run through this truck including the differentials. I change the oil + oil filter every 5K miles and fuel filters every 10K.
Every 2-3 years I coat the underneath with POR15, including the oil pan. I avoided trying to drive on salty roads, but living in Wisconsin I don't have much of a choice; after heavy salts I would power wash the undercarriage. With that said, I have noticed two rust spots on the rear wheel wells. I have since ground and coated in por15 and fluid film; I have also had factory style fender flares professionally paint matched and installed for added protection.
Two years ago, I put all new cross-drilled rotors and pads all the way around. Also, about 10,000 miles ago I put brand new Nitto tires on the truck.
Two other things to note: rear back up lights don't work, unfortunately I don't have the factory tail lights, the truck was bought with the smoked rear LED lights and the e-brake shoes need to be tightened.
Price: $17,500
Email me if you are interested at tcm1984@hotmail.com or call 847-873-6965
Please note title is free and clear.
Firefighter 1406
6.4L Power Stroke Diesel
21
07-23-2017 07:53 PM
fordborn
128
06-30-2008 11:20 PM
