2015 interior colors
Are charcoal and black two different interior colors in 2015 for lariat f350 diesel models? My window sticker shows black as the color but an interior part I need comes up as charcoal. I'm not sure if they are one and the same or not.
I want visor with homelink part number BC3Z-2504105-GB which lists as $300. FC3Z-2504105-GB is a number it replaces and is only $80 and listed as charcoal.
Thanks.
Thanks.
Well not sure if anyone will be able to find this thread given the subject, but I thought I'd follow up.
The new visor came and works great, and yes, it is HomeLink and not Car2u, and for only $80 delivered!
It literally SHOULD have taken 5 minutes, but the connector for the harness was above the headliner, about 3" behind where the visor mounts, so I had to pull the door seal, and reach between the roof and headliner and work blind. The wire and connector are fastened to the headliner with sticky foam mats, so I had to pull that back to get the connector free, disconnect, then connect the new one, all while not being able to see anything. It is easy, but you just need to be patient when working in the headliner.
Once done, it took me about 5 minutes to program my 3 garage doors. So nice to have that feature back!
saucemann
2017+ Super Duty
11-30-2017 07:47 AM
marktrot
16
05-16-2015 11:06 AM
