IDI Turbo, confused about kink in exhaust upgrade
hturner12
My truck is N/A and I have not seen a turbo installation up close, so I ask my questions out of ignorance.
Are the down pipes round? Would it be possible and beneficial to use oval pipe instead? If the stock down pipe is 2.75" diam., would a 4" oval as shown in the attached pdf fit and provide better flow at the same time?
Jim
Jim
Here is a link to the current banks
21062 Sidewinder Turbo Syst; Wstgtd-1989-93 Ford 7.3L Trk; E4Od
Here is hypermax
https://www.gohypermax.com/ProductDi...6-923cb9edcee1
ATS does not support IDI anymore
Hugh, I don't have a turbo yet. But I want to have one by June when my wife and I move back out west. My truck runs pretty good, but it needs better air flow going up the high mountain passes. Especially when towing a good load.
Anyway to get back to the turbo question. After looking at the Banks installation diagrams, I assume when you say down pipe, you are talking about what Banks calls the turbo outlet pipe that goes down the firewall and connects to the rest of the exhaust?
Banks instructions have us bend the firewall back to make enough clearance for the 3" round down pipe. My question was why couldn't we use a 4" oval pipe that measure 2-3/4"x4-5/8" and equals the flow of a 4" round pipe instead?
Am I understanding things correctly, or am I lost and confused as usual?
Thanks, Jim
Thanks, Jim
the later years that came from Ford had a problem either the pipes being almost flat. Think about this big trucks use round. I think oval would have sealing problems. You can get a tailpipe for an early PS for around a 100 bucks. I did that for up and over the axle the a 4 in muffler and a stick of 4 in pipe sealed everything with band clamps. Had pipe left over
ram2miller
10-28-2010 08:19 PM
