Idle problems
Do a search on here or Google and there is a plethora of information on how to and I'm sure video's.
Your wallet will thank you before throwing any parts at it.
Code 21: ECT out of self test range 0.3 to 3.7 volts.
Code 24: ACT sensor out of self test range 0.3 to 3.7 volts.
Code 67 (KOEO): A/C ON during the KOEO tests.
Stored Codes (CM)
Code 29: Insufficient input from vehicle speed sensor.
Indicates the VSS signal has been low at some point during operation.
Code 33 (CM): EGR valve opening not detected.
Indicates the EGR feedback has not changed when the EGR was commanded open by the computer at some point during operation.
Codes 21,24 indicate the truck was not fully warmed up before running the Key On Engine Off (KOEO) tests.
Stored Codes (CM)
Stored Codes (CM)
A rolling idle can also be caused by a faulty TPS (even though it may not flag a code), worn throttlebody or worn throttlebody blade shaft bushings as well as previously mentioned vacuum leaks.
TrucknAustin
12-27-2020 04:16 PM
jim2029
09-08-2008 09:01 PM
