Suddenly dead battery
Old 01-19-2017, 04:20 PM
TobaccoBarn460's Avatar
TobaccoBarn460
TobaccoBarn460 is offline
The starter grounds by virtue of it's metal base being mounted.
I thought I've heard of rust or oil leaks that caused problems in that area.
If you negative cable to the block is new, clean, and tight you should be starting to look good for that circuit.
  #47
Old 01-19-2017, 04:31 PM
88n94's Avatar
88n94
88n94 is online now
Originally Posted by MTP55
Where is the block to starter ground located? And how do you get to it? I've been looking and can't find it. The engine is. 5.8
I don't know if such an animal exists on these trucks.
If it exists and it's still there it would have to hook onto one of the bolts on the starter OR go onto one of the bolts that hold the starter to the transmission. The other end would have to bolt somewhere on the block.
Such a ground shouldn't be needed because the the transmission bolts to the block and grounds by the transmission hugging the block as well as the bolts going through the transmission housing to the block.
The bottom line is I doubt if there is such a thing on your truck, but I could be wrong.
  #48
Old 01-19-2017, 04:33 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Sometimes folks get carried away with paint during restorations, the starter grounds itself through the mounting boss on the block. Clean bright and shiny tight won't hurt anything here. Fresh, heavy duty cables and grinding through the grime and corrosion before connecting makes a big difference in both starting and charging. Then check for voltage drop with a DVM set on its lowest setting. Nothing should exceed a few tenths anywhere. Here's how it's done, a little different procedure than people might think. You could check, if you wanted, for any voltage drop between starter and block for example.
http://www.aa1car.com/library/voltage_drop_testing.htm
  #49
Old 01-19-2017, 05:08 PM
MTP55's Avatar
MTP55
MTP55 is offline
I'd go along with that being as I can't see anything that grounds except the base of the starter. I bought a brand new starter so it hopefully will work better than the reman. Thank you for your responses and I'll let you know how it turns out after this.
burnout01134
1997-2006 Expedition & Navigator
03-18-2016 01:33 PM
Science1974
1999 to 2016 Super Duty
13
10-17-2014 08:51 AM
BillyBob69
1997 - 2003 F150
11-02-2006 02:00 PM
xXDravensRainXx
1983 - 2012 Ranger & B-Series
12-31-2005 10:48 AM
demegod999
03-07-2004 07:39 AM
Quick Reply: Suddenly dead battery
