Correct thermostat 460
Old 01-02-2017, 09:55 PM
PapaBearYuma's Avatar
PapaBearYuma
PapaBearYuma is offline
Copper truck: 77 F350 460 C6 4x2
So, what's the correct thermostat? Style and temp, please
Thanks!
Old 01-02-2017, 10:03 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
F-250 WARHORSE is offline
As far as I know the ford v8 thermostat in a 192 or 195 but correct me if wrong.
Old 01-03-2017, 02:02 AM
Daveycracky's Avatar
Daveycracky
Daveycracky is offline
OEM is as Warhorse said, though Scotty the Mad Porter from the 460ford.com forum recommended a 160 high flow for mine as a mild performance build. Scott built mine so I go with his recommendatation, no idea if that applies to a stocker. Here's a link to that question and answers on that forum.
Recommended Thermostat Temperature - 460 Ford Forum
Old 01-03-2017, 04:10 AM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
Thanks!
The original from Ford as built was a Robertshaw 205°F Hi Flow T stat. See below.
If you are not going to use a hi flow stat then 195°F If you are regularly hauling heavy loads or towing heavy trailers and finding that the engine is getting to hot with the 195°F step down to a 180°F.
On a regular street driven vehicle with a properly operating cooling system you never want to run any thing colder than 180°F, cylinder wear goes up drastically once you start running an engine below 180°F. See below
Old 01-03-2017, 10:25 AM
somethingclever's Avatar
somethingclever
somethingclever is offline
i like a 180 robert shaw in my 460's.
Old 01-03-2017, 10:27 AM
redmt79's Avatar
redmt79
redmt79 is offline
Motorcraft RT-1067-A comes up on Ford Parts. Not stated in description but I believe it's a 190-something stat. I use this stat in my 460 under all conditions and it's been very consistent. Also, the nice thing about Motorcraft stats is they have a nifty little bleeder valve that makes filling coolant a cinch without creating air locks in the engine.
Old 01-03-2017, 12:05 PM
PapaBearYuma
Thanks guys! I ordered up a pair of Motorcraft RT-1067-A thermostats.
Old 01-10-2017, 05:25 PM
ricteroff's Avatar
ricteroff
ricteroff is offline
thanx for info
Old 01-10-2017, 08:42 PM
PapaBearYuma
Thanks, again, everybody for the info on the thermostat. On Sunday, I installed the new thermostat, flushed the cooling system, and refilled with three gallons of Prestone concentrate.
Heater works great, truck warms-up nicely, and both gauges reflect the expected temps.
Very happy
Old 01-10-2017, 09:05 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Parts catalog pic: Where is the 205 degree t/stat? No see um.
Old 01-11-2017, 10:21 PM
fasthauler's Avatar
fasthauler
fasthauler is offline
I have been running the 180 in mine for years. It gets hot enough towing with the 180.
Wolf82636
03-08-2019 08:19 PM
vettman
10-10-2006 09:48 PM
parkway
02-20-2005 08:52 PM
jcm
1999 to 2016 Super Duty
01-03-2003 09:03 AM
Quick Reply: Correct thermostat 460
