Toy hauler sunk
sorry human powered backhoe = a shovel.
In the fire service we use like 4x4 square post and cut them into approximately 2' lengths and then drill a hole through them on one end. Then use some scrap rope to make a loop through the drilled hole.
now you have some easily stackble cribbing that is easy to retrieve and store.
A tripod with sufficient strength would've worked to temporarlily hold the pin up while you retract the landing gear and fill and rebrace the pad they sit on. or a couple 4X4 posts to hold it temporarily to reset the landing gear.
Either way, glad you got it out!
I went and bought 2 pressure treated 6x6s and cut it into 18-24" pieces. When I having to put the camper in soft spots, I use 2 of the 24" side by side as a base with 2 18" ones criss crossed on top of those for my landing gear to sit on. Givens me a good base, high enough and also gives me cribbing in case I have to jack it up on the road for some reason.
I'm glad you got it out and good job thinking outside the box!
JacoFordCummins
Engine Swaps
45
11-04-2020 09:09 AM
rangerbait
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
18
07-14-2015 02:51 PM
