Heater issue partially resolved?
Hey all, OK, I pulled my dash, and replaced the vacuum lines going from the interior to the engine compartment. I also replaced the lines going from the heater/temperature control to the connector under the glove compartment. Now I finally have heat, BUT I needed to take a Zip-Tie and hold the Vacuum valve in the Heat position because I can't get it to work just off vaccum. I don't know where the issue is but I have two lines coming from the interior, one goes to the valve, and one gost to a "Tee" the other line going into the Tee comes from the Heater Housing, and the third line comes off the Vacuum tree on the side of my 4.9L. When i start the truck and disconnect the lines I can hear and feel vaccum. But it doesn't seem to change when i move the heater controls in the truck. I am wondering if the control piece itself is bad. All the doors function, I switch from Defrost to Heat and Floor no problem, Just couldn't get the heat.... now today for the first time I did get it after I had replaced lines and zip-tied the valve...I would like it to work as it should though and am trying to figute it out. Any advice
1994 F250: 351, C6
01-24-2009 02:14 AM
