Removing smog equipment
I am currently replacing engine in 91 F-250 with a 5.8 and I am removing smog stuff. I am going to leave all the electical connections in to keep CEL off but my question is can I remove all the vacuum hoses from the diverter valves that sit over drivers side V/C without making it do anything crazy.
on
You can safely remove all the air injection plumbing and remove or cap the vacuum lines that fed those valves, but don't forget to plug where it connected to the exhaust or you will have a problem, there should be no leaks in the exhaust upstream of the O2 sensor. The EGR system cannot be eliminated without setting codes but it's just 1 valve and vacuum line so it's not that bad.
Camacorn
10-12-2016 08:18 PM
dleavitt
17
09-13-2016 08:04 AM
Soarer
03-29-2014 09:40 PM
WoodworkerJon
04-18-2004 08:46 PM
