DIY OEM Remote Start install not working
I recently installed remote start kit #BT4Z19G364A into my 2012 Ford F-250. After programming the remote start parameters in Forscan (effectively doing what the dealer would do in the IDS computer) the remote start system seems to be interfacing with the truck. However, it will not start it. I have programmed the remote successfully, and now when I try to start the truck, I get three beeps and green blinks from the fob, which I have read indicates an open door circuit (?).
When I installed the remote start computer, there was a 4-pin orange port on the back side that I did not see a plug for. Does this need to be connected to something on the truck?
Thanks,
Doug
Thanks,
Doug
I have not seen anyone use this kit for long distance remote start. I believe it was superseded by breaking it into various different kits and a totally different control module.
You installed hood switch? BL3Z-19G366-A
Looking at the kit you have listed as using on eBay, I do not see a hood switch as part of the kit.
If you need additional remotes, you can use this FCC ID ELVATRKC to get a single button remote on eBay. BTW, the one with Subaru on the remote work with Ford since same FCC ID.
ELVATRKC | eBay
Oh, btw, the orange port you said is probably for the cellphone access module.
ELVATRKC | eBay
I was hoping to avoid going to the dealer by using Forscan. Looks like I'll have to drop the truck off and see if it is just a programming issue. I'll save before-and-after "As-built" data and see what changes were made by the dealer IDS computer so that others will have it in the future.
Both the RF antenna and the TPMS plug connections were made.
Gotsmoke12
6.7L Power Stroke Diesel
12-31-2015 07:31 AM
