Weird ICP voltage issue
I have a no start thread going but am looking for anyone who has experienced this ICP voltage issue.
KOEO numbers for ICP voltage is .07 - I know it should be .24 or so.
With the ICP plugged in, I get a no start as, while cranking, ICP developed reads only as high as 362, IPR maxes out and ICP voltage gets only to .18. I know ICP has to read at least 500 to start, and the IPR shouldn't be maxed and ICP voltage should be in the 1+ volts range.
If I unplug the ICP, voltage of course reads 0, IPR while cranking reads on the order of 75 and ICP number developed by default reads 1667. Still no start and I just know most of the time it would start given these numbers.
I installed a new EOM ICP sensor and got the same readings, I changed the pigtail and get the same readings. I even purchased a 2nd new EOM ICP and get the same readings.
I find no chaffing along the wire loom but will cut open the cover and trace all the way back to make sure.
I haven't been able to figure out which fuse covers the ICP?
Also, FICM is showing correct voltages at 48/11.5/11.5.
Anyone have suggestions as to the ICP voltage - I'd really like to get it figured out so I can see what actual pressure is being developed?
The following users liked this post:
I don't doubt it Mark. Thanks for the references. I'm still concerned with getting the ICP voltage corrected too. Trying to eliminate it before I tear back into the rails, etc. I've already done the standpipes, dummy plug, STC and injector orings.
That leaves the cups/Orings and HPOP (2006 motor). Most of the research I've done has indicated those 2 rarely fail?
This all started with a hot not start and the only actual indication I found of an issue was a torn oring on the passenger side dummy plug.
Did you check the reference voltage at the ICP plug with a meter? Maybe you have a short on the 5v reference voltage circuit. If the volts are below 5v, check other sensors, such as EBP, first by unplugging them incase the sensor is bad. Then check at those plugs for 5v. Then inspect chafe on the harness.
I just don't think that is an issue.
Ford's number is 0.2 (and it varies slightly for early vs late model years - I just can't recall the exact differences) ......... and you are at 0.1 (for all practical purposes).
If it won't star1ft with the ICP unplugged, it is not an ICP sensor value causing the no-start.
I'll go back through air testing again tomorrow and see if I can figure it out.
