Glow Plugs
Glow Plugs
Ok guys, got a 96 f250 4x4 7.3 5 speed. It has a little over 250,000 miles without anything ever done to the engine except a new GPR years ago, one of the good ones. I'm going to put in new glow plugs. so what are best ones to get. I also figured since I was in there I would replace the relays and such. So just what all should I replace and what brand. I'd like to get a kit if I could with all the stuff in it, a good one, but reasonable. maybe off ebay............what is the consensus and recommendations out there.
Yep I changed out the GPR years ago with a really good one and have never had a problem. So I'll get the motorcraft glow plugs. I'm also going to get one of the valve cover harness kits. I can seem to find a Motorcraft valve cover harness set on ebay, but there are several after market ones, any suggestions.....Once I gather up the parts I'm going to have a mechanic I know change it all out, he's really reasonable.
Something to consider would be changing to the Super Duty valve cover harnesses. It is not a direct swap as the SD uses 1 plug per side while the OBS has two. The main benefit is that the SD pins are larger so that pin burnout is reduced. Do a quick search as there are several threads on it.
Received 3,101 Likes
on
get the glow plugs from rockauto. they are $9.26 each
use this discount code for 5% off:
5% Discount Code: FBE6192C603F43
Expires: March 13, 2017
Please enter this code in the ‘How Did You Hear about Us’ box to receive the discount. Please enter ONLY the discount code, no other words or numbers. Please note that orders using discount codes must be placed online and the discount code must be entered before an order is submitted to receive the discount
StevensPoint
03-26-2008 12:18 PM
