Transmission Identification
Thank you......Mark I bought this truck and after about 300 to 400 miles it loss reverse and was slipping bad in all forward gears. After researching from previous owner and looking thru the invoices in the glove box we discovered this transmission had been rebuilt by a transmission shop just prior to my purchase. The trans shifted really hard thru the gears. Replaced it with a rebuilt trans from local parts store with new torque convertor. This one did the same except it has not loss any gears yet but it slips in the forward gears and shifts hard.
PLEASE help if you can !!!
I will agree with that......the tool I have is an OLD OTC genesis and to be honest I really don't know how old the tool is but it does have a reader card for up to 2002 domestic vehicles.
I will get it to someone with something a lot newer, what tool would you recommend to use ??
I have a '96 F 350 same as this truck that the trans worked perfect, we took the ECM and speed sensor out of the '96 and put in the '97 and the trans in still doing the same thing.
Was thinking if anything was wrong with the ECM in the '97 this would let us know.
Was this a bad swap ??
Well if the swap should have worked then your area of knowledge is the trans, then where else do I need to look ??
I don't want to make you angry but is there any other control module other than the one in the left side fender well ??
I know I cant' get Ford motor service tools but I believe there are other scan tool out there that are capable of reading these codes.
And if the swap did not correct the problem then my experience is that the problem may be in the transmission.
Mark I am no dummy nor am I a genius but as a heavy equipment diesel mechanic for 38 years we try parts of off a well know working donor rather going to the parts store and buying parts and being a parts swapper.
Please help if you can, is there a separate cm for the trans ??
Last edited by 66 sandrail; 01-03-2017 at 02:29 PM. Reason: cat jumped on laptop and caused it to mess up !!
There is not. The engine and trans share one. It could be a wiring issue, or it could be a PSOM issue.
92 Xplorer
10-04-2002 04:29 PM
