Can't catch a brake
Can't catch a brake
On my 2007 f350 when I hit my brakes it pulsates... so I put new rotors and brakes up front.. the pins are good and the calibers are good... put it all back together and still the same thing... the slower you go the slower the pulsating gets... and I can actually feel the pedal move in and out when it does it... I'm lost
can you feel the truck pulsate ?
No .. apply the E Brake just a little more .. still no ..
maintain the E-Brake pressure until the truck stops.
If you felt the pulsation, you've isolated it to the rear brakes.
If you didn't, I'd re-address the Front Brakes.
Also .. (if) you've diagnosed the pulsation to the Rear Brakes, while you have everything apart, ensure the E-Brake cable is working properly and lube all of it's contact points.
Try driving (very slow) and GENTLY apply the E-Brake ..
I (assumed) your Rear Brakes were Disk .. my bad !!
