hard to put gas in my 2006 E250
Old 12-29-2016, 05:48 PM
tim54's Avatar
tim54
tim54 is offline
I hear it's a common problem with Ford trucks that it can be hard to fill with gas unless you put it in real slow but I have heard many reasons why. Any consenus out there on how to fix it? Thanks
Old 12-29-2016, 09:32 PM
Teutonics's Avatar
Teutonics
Teutonics is offline
I have the same year model and have never had an issue filing mine. Maybe a vent tube is blocked or hose is kinked or something?
Old 01-08-2017, 05:53 PM
Derbyman's Avatar
Derbyman
Derbyman is offline
What kind of problems are you having? One fuel station I go to the handle keeps clicking off but only at that one fuel station.
Old 01-09-2017, 01:12 AM
vettex2's Avatar
vettex2
vettex2 is offline
hold the nozzle up
all the fords I've dealt with are fussy
Old 01-09-2017, 11:37 AM
spikedog's Avatar
spikedog
spikedog is offline
Welcome to FTE, tim54!
I have the same issue with my 2006 E-450. It's a diesel, so the fuel foams up a bit more than gas does. It depends on the station, but sometimes I have to stand there and nurse the fuel in for over 10 minutes. It's pretty tedious, and I often give up well before my tank is full.
As far as a cure, there is a procedure called "harpooning". The fuel filler tube extends well down into the tank. I think both gas and diesel Fords use the same fuel tanks, but its more common to harpoon a diesel than a gas fuel tank. This extension causes foam to travel back up the filler hose at a lower tank level than if it dropped into an open tank. Cutting off the PVC vent hose even with the top of the tank can be done with the tank on the ground, using the access port the fuel pump goes in to get a blade in and cut the plastic vent hose extension. I've heard it seems to help, but I'm only going to do it if I have additional reasons to drop the fuel tank.
https://www.ford-trucks.com/forums/1...e-up-pics.html
Mike-11
1999 to 2016 Super Duty
64
12-09-2023 12:38 AM
Bohemian
Modular V10 (6.8l)
15
10-20-2020 07:26 PM
gstirewalt
07-12-2013 04:27 PM
allisman1
12-31-2010 10:07 PM
steve81
01-07-2004 09:13 AM
Quick Reply: hard to put gas in my 2006 E250
