Modular V10 (6.8l)
Wit's end with coolant at exhaust!!!
Old 12-28-2016, 09:10 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
ROBBINthaHOOD is offline
I was having an issue with coolant loss and white smoke from tailpipe. Was told it was likely intake leak vs headgaskets. Changed intake gaskets, fixed the issue for a day then it started just dumping coolant from every available place in the exhaust system. Was draining a full collant bottle in about 2 minutes. Was also checking for exhaust in the coolant with the tube and blue liquid which it stayed blue. Had previously done a degas pressure test and it passed. The only test I hadn't performed was compression test which all the cylinders output was lowest 160 to the highest about 185. Did not perform a wet compression test as I was mainly looking for base compression and consistency. Not sure what healthy is on these vehicles but considering they were all running pretty close I call it good. Also it idles just as smooth. Pulled intake a 2nd time and rechecked my previous work. Everything looked fine so I put it back together. Ran smoke free for about 50 miles now I'm back to smoke after it sits a bit but it clears up after a short drive. What am I missing? I will note that I had a small coolant leak from drivers side rear of engine that I noticed while it was parked in the shop. I'm assuming that would be the oil cooler? But oil is clean so it's not mixing. What other avenues on these engines can coolant make it into the exhaust? Drives perfect with no powerless. Thanks.
Old 12-29-2016, 06:03 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Pull the plugs and see if there's any coolant on them, or if any particular plug is discolored.
Oil cooler leaking wouldn't wind up in the exhaust.
Also, help us out - what vehicle, year, model, etc.
With the reservoir cap off, is there any bubbling?
Old 12-29-2016, 11:11 PM
ROBBINthaHOOD
2001 Ford Excursion V10. No bubbling in coolant bottle. Degas pressure test held around 5-7 psi. The combustion in coolant test passed with the blue fluid. Spark plugs are dry. Compression is 160-180 on all cylinders.
Old 12-30-2016, 06:52 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,188 Likes on 816 Posts
You sure its not leaking? Also check your PCV system I think on the X came with a heated PCV system might have a crack allowing the coolant go into the intake manifold.
Old 12-31-2016, 12:11 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
That could very well be it - I was wracking my brain trying to remember where coolant was used. I knew it was for something, but couldn't remember exactly what - I was thinking EGR, but it's not a diesel
ROBBINthaHOOD
Modular V10 (6.8l)
07-11-2017 07:51 AM
ROBBINthaHOOD
01-03-2017 06:08 AM
metal13x
1997 - 2003 F150
02-26-2008 08:16 PM
biederboat
1978 - 1996 Big Bronco
05-16-2005 10:49 PM
1SG
01-26-2004 10:13 AM
Quick Reply: Wit's end with coolant at exhaust!!!
