6.2L V8 Discuss the 6.2L V8
Tailgate cap recommendations
Old 12-27-2016, 09:01 AM
oceantrav's Avatar
oceantrav
oceantrav is offline
Got a 2011 f250.
Tailgate cap is missing, and the top is a little beat up from use. What options do I have?
I see those $30 black metal after market ones on Amazon, but can't find one for my 2011 f250.
If I go OEM and spend $60-70 im worried that some of my holes for the clips won't work since they are bent up, so it might fly off. Could I use 3m tape and some self tapping screws to secure it?
I see this a lot, so sure there's a simple solution.
Thanks
Old 12-27-2016, 10:28 AM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
I think I would go with an OEM cap, and self tapping screws with grommets/flat washers if it was me. But this is without seeing how badly puckered up your edge is on your tailgate.
Old 12-27-2016, 10:31 AM
oceantrav's Avatar
oceantrav
Thanks for the response. Ordered the OEM off amazon for $60.
All the aftermarket ones didn't cover the entire section the OEM one does. Guess I'll use some self tapping screw I have, then hit them with black spray paint so they blend in kinda
Old 12-27-2016, 12:57 PM
Slowpoke Slim
Put some flat washers and/or grommets between the screw heads and the plastic, so it's less easy to rip the cover through the screw heads.
Old 12-27-2016, 12:58 PM
oceantrav's Avatar
oceantrav
Good idea. Will do.
Old 12-27-2016, 01:26 PM
gstanfield's Avatar
gstanfield
gstanfield is offline
When I bought my '13 it was missing the cap, but not dented up. I ordered a new OEM cap from Amazon of all places and when I removed the tailgate access panel to replace the cap I put the angled lip part of the panel in my brake and lightly tweaked it a tad so it clamps tighter on the front, bottom edge of the plastic cap. I can't say that I was necessarily in need of tweaking, but I figured it wouldn't hurt and at least I have peace of mind that the new cap has a better chance of not flying off.
Blaiser
1999 to 2016 Super Duty
10-15-2016 06:57 PM
dwilliamsceg
16
04-06-2016 09:30 AM
mwmartens
2004 - 2008 F150
08-29-2012 01:29 AM
Gwilkrrs
6.4L Power Stroke Diesel
02-04-2011 06:38 AM
big dude
2004 - 2008 F150
09-30-2008 08:15 PM
Quick Reply: Tailgate cap recommendations
