P0269 and P0611 codes
Hi all, my 2007 F350 crew cab DRW 4x4 started missing on Saturday and today is smoking excessively and throwing the P0269 and P0611 DTCs. The truck has a BPD EGR and their big oil cooler and filter relocation, and is straight piped. The Deltas have not changed with these symptoms, and using torque pro, the FMP is constant 54v.
Does this sound like a failing FICM?
P0611 is an FICM malfunction that in my opinion could contribute to the p0269 which is a cylinder contribution problem. What are your ficm voltages not running and running. Your probably looking at an ficm repair. If so I'd contact Ed at ficmrepair.com
I think we were about 30 seconds apart Mike.
I have not read much about the whole 54v FICM mod but what little I have read was there is an arguement for the actual need for it, and the potential for trouble it might cause.
If you neber had a 611 code and now do with no hardware change on the FICM, then your code is not voltage mod related.
I am am on vacation this week, but if you call the shop at the 515-897-4459 number and leave a message for me, I should be able to get you called back later this afternoon pretty easily.
Hope you had a great Christmas!
madMatador78
17
01-16-2016 07:40 PM
Johnny Bravo 45
05-16-2014 01:31 AM
