2001 F250
2001 F250
I just bought a 2001 F250 4x4 auto with the 5.4 gas engine. I have only filled it up a few times because it sits most of the time.
Anyway, shouldn't I get better than 7 mpg?
I have changed plugs and boots, new fuel filter, new air filter and pcv.
Did not help much. Still only getting 7.6 mpg.
It did set a code last week. It was output speed sensor.
I have no idea what that is.
Any ideas about the mileage?
Thanks
Thanks
I had an 04 5.4L F250 CC 2wd auto that I put 206k miles on that got 13-14mpg empty. It had a 2" leveling kit and a slightly bigger tire when I upgraded to 18" wheels (stock 4wd tire size). I also had magnaflow performance exhaust and I ran amsoil through it, which helped me 1-2mpg's. Stock, I was getting 12mpg. 7mpg sounds awfully low to me even considering yours is 4wd.
Check to make sure of a few things.
Calipers aren't sticking or stuck and move freely
Make sure your hubs aren't locked in 4wd
How many miles are on the truck, and what configuration is it?
Lastly, look at the door tag under AXLE and see what code it says. If you have larger gears it will slightly effect mileage
Thanks
Thanks
