Quad Beam Halogen to LED
#31
Another thought: is the BLISS inherent in the vehicle just waiting for the input from the tail lights and activation? Or is there a separate module added to the system to interpret the data? In other words, could BLISS be an easily added feature with the correct tail lights with sensors?
edit and wiring harness.
#32
#33
I'm guessing the radar taillights, required body harnesses, mirrors and harnesses, and programming would be a whole lot more expensive than the $540 factory option.
#34
#35
Streamline GT, I had received word from Raptor Retro fit they will be coming out with a kit crossover for the 2017 F250 to change over to the LED lights hopefully this month, still waiting on them, please share what you come into thanks. Hey FDNY136 are you on the job I recently retired from Miami F.D. Fla.
#36
#37
I am on the job yes ret. fdny.I will get the name of the guy I got the tail lights from.I do not know if you can retrofit bliss.I am waiting for led headlamps to come in,they are backordered and I have raptors harness and am going to test and see what has to be done for the superduty and get back to dawson
#39
There is a ballast.....
The claim from Fairway Ford is the lights need additional ballasts. Personally I can't see LED lights needing ballasts like an HID light but who knows.
I'm not sure the wiring would all cross over. The LED headlights do not have amber parking lamps in them...instead they have configurable LED DRL lights. The signal driver for the turn signals may be different as well.
Yes, there is a ballast for the LED lights.. Part# FL3Z13C170A
#42
#43
#45
I stand corrected. It appears the ballast is for electricity regulation. Whether F-150 or Super Duty, it proves there is indeed a ballast for these lights.
It doesn't surprise me the part numbers would be the same. The LED light elements are identical between the SD and F-150.
Thanks
Thanks
