FE 390 Hydraulic Lifters help
Currently researching and collecting parts for my 390 build and for most part things are wrapping up quite nicely. But I do have a question in regards to the choice of lifters. I know I will be using hydraulic flat tapped lifters with non adjustable rockers. I am looking into a Lunati P/N: 10330701 cam, but there is also a choice of purchasing a kit with it, which comes with lifters. I do have stock lifters from my old block and they are in good condition. Lunati claims their lifters are superior and weight less. Crane offers anti pump lifters CRN-99281-16.
I have three choices from which to chose. If anyone could give me some pointers on choosing lifters it would be greatly appreciated.
Nick
Nick
I would recommend from personal experience that you go with new performance lifters. The Crane or Lunati lifters bleed off faster that stock Ford lifters to prevent "lifter float", a condition that occurs at high RPM and the lifters don't allow the valve to close securely. You also need to use a set of High RPM valve springs. I used Crane's springs. They insure both intimate lifter to cam contact and offer the resistance need for the hydraulic bleed off of the lifter at hi rev's. I had a dual point distributer and I was making power thru 6,200 rpm. That's as tight as I would wind a FE unless it was a 427 Side oiler with the side bolts on the mains. PS, Don't forget the cam lube.
Nick,
Lifter metal has to be compatible with the cam metal. Use the matched-set lifters offered by the cam manufacturer. Mix at your own risk. You might check with the cam manufacturer, as they may have an idea if the heat-treatment is compatible.
It is important, as the cam needs to rotate the lifter a little in it's bore. This prevents the cam lobe from being wiped out (eroded).
Nick-1973-ford
12-31-2016 10:18 AM
zsir
22
09-05-2005 02:46 PM
siphor84
07-10-2005 01:05 PM
bigblockhead
03-18-2000 08:56 PM
