Fuel leak near fuel bowl...help.
So just got back from a 3 hour round trip to find out i have a fuel leak near my fuel bowl. I dont know what the part is called nor exactly where on it is leaking. Its literally right bellow where my finger is.
what is it, why would it suddenly start leaking and be leaking "when truck is running only"? How do i fix it too and is it an expensive fix, shop vs DIY?
Op. Be ultimately careful screwing that in if you ever have it out. The housing is THIN!! You will brake it.
Below your finger there is a line that the regulator pushes over. The regulator has an oring init and the tune pushes in . I had that leak once upon a time before I "fixed" my system properly once and for all.
That's the fuel pressure regulator, there's two O rings being it, just remove the two 10mm bolts and you will see them also a good chance to clean the fuel pressure screen. Just make sure you use Viton O rings or look into riffraffdiesel.com he's got what you need for your rig.
Riffraffdiesel.com has all you need.
As for removing the housing no need to remove the fuel lines its kind of cramped butcan be worked on, man I'm trying to find a exploded view but can't find one here's one from a 95
https://www.ford-trucks.com/forums/a...1&d=1276027719
i did end up having to renove most of the lines going into the regulator. There is a line going into the bottom that is a formed steel line that i cannot get off. I cant get the regulator to come off of the fuel bowl until that forned line is off. Wtf....this thing is being a pain. How dies the line go into the regulator? i cant find a head to put a wrench on.
P.S. is it just worth replacing the regulator NOW while i have it out and save myself future headaches? What can i put on that slip in line to have it seal better?
i also only found one o ring and i found the screen.
aparently the steel formed line just slides into the bottom of the regulator...hmmm doesnt sound very secure, since it was leaking from the bottom of the regulator, i am going to assume it was that slip in line that was leaking. Pictures to follow.
