Front Cab Corner Help!
When I removed my front clip I had to cut the bottom bolt, that holds the fender, off because it was so rusted in. I would like to treat the back side of the bolt but it was full of mouse nest and dirt. Any tricks or tips of how to get this cleaned out? My hand is way to big and I cannot see in there worth a crap. There is very little room because of the door hinge support. Does this support come out? It looks like it is welded in and part of the cab. Also, at what point is it a good idea to replace the cab corner? It looks good on the outside but I am sure it is rusted on the inside and almost impossibly to de-rust. What have you guys done? Thanks for any tips and/or pictures in advance. Dave
I have used my Shop Vac. Unfortunately it is to big to get down to the bottom. I guess I'll bite the bullet and go buy a skinny hose. What makes me mad is I have one but can't find it! Does that ever happen to any of you guys?
Wow, thanks for all the suggestions guys! It's good that you can all share your experience, but sad that the Ford cabs have this issue. I guess 61 years isn't bad! Does anyone know if these truck originally had a drain hole in the bottom?
I don't want to open it up either! Not sure what the 55' corner looks like, but am going to check it out as soon as I'm done here.
I have something g I use to clean out the dryer lint collector and hose. It is a plastic nozzle wider at one end that slips over your shop vac hose, then a clear plastic tube slips over the other end. You can stick Otway down into the dryer. You could probably rig something like that with a length of hose duct taped o to you shop vac hose.
There is a reason that the 56 model has the inspection plate, it took Ford a few years to figure out that there was a need to get into that cavity to access the bolt/anchor nut and to clean out the cavity. "I would like to treat the back side of the bolt but it was full of mouse nest and dirt."...this is an issue with many F100 owners, the drain clogs with debris and then the water sits and rots out the cab corner. All the cabs that I work on get inspection plates...it's a simple fix and a good thing to do.
Don't get too carried away with what fits and what doesn't...I cut an opening out that looks like the one on a 56 but don't pay too much mind to making it an exact match. The idea is to make the opening large enough to get in there and clean out the debris. I cut a cover plate using 18 ga steel, I like to keep it thin enough to cut with tin snips/shears. I use a couple of self-tapping screws and it's good to go. Paint the cover with Rust Seal or some other quality paint...I also brush a liberal quantity of paint inside the cavity before installing the plate.
Here is a pic of a 54 cab that I just did...it gives you an idea of what it looks like when installed.
