Raked or reverse raked vans?
Anyone have any pictures of vans that are either rated or reverse raked?
And if anyone owns one what's the effect on handling.
Can't seem to anyone doing anything with these vans. I know the twin ibeams limit you, but if it would look good, I was thinking flipping the rear axle, and having an auto collision shop bend the beams enough for mayby a 2 inch drop in the front ending up with about 3 inches of rake front to back.
We have talked about lowering vans on this forum a few times.
One issue I have noticed is that I only have a few inches of travel between the rear axle and the frame/body. I wonder if yours is the same.
The other issue is that bending the I-beams is a fantasy more so than a possibility. We have spoken on here of finding drop spindles but no one has been fruitful that I know of.
I would seriously consider a 3 to 5 inch drop of my van if possible. Let me know if you find any good stuff.
Well I looked closer at the rear end and your right the frame is closer then I would like to flip. So I guess I'll have to de arch the springs and do a little drop or do a partial c notch to flip it.
I've heard that old school truck shops can bend the beams on some other forums but is this not really effective?
I'm just saying no one on this forum has claimed to successfully bend the I-beams. Lots of people bring it up for conversation but it never seems to happen. ( like in the V10 section how people always come in there talking about turbo chargers and superchargers on their engine and it never happens. )
I like your determination and I like your project idea/goal, but are you sure you want to do that much modification to your van? That's a very big project you are talking about. Modifying the actual frame on a 6000 pound vehicle is a serious undertaking.
I might have missed it but did you say what year your van is? If it's a 75-91 then you've got king pin front I-beams. 92+ will have ball joints.
With the king pin I-beams you can lower the front. It requires changing or cutting the front coils and then having the beams bent at a truck shop to correct the camber. Bending the beams is the only way to adjust the camber on the king pin beams.
A lot depends on how much you are trying to drop it. If you really want to slam it then you would be looking at having to hunt down or fabricate some dropped I-beams.
I drive the sh*^ out of my van: those bumps are well utilized.
i have seen some frame-modified, slammed vehicles, but they are:
1. Small : two seater small pickup trucks
2. Just for show : ain't nobody mistaking them for actual daily useage.
I like lowered vehicles and if I found drop spindles for my van I would definitely want to get them. (Then struggle to make a plan for the rear suspension).
Keystoner16
06-04-2017 12:18 PM
55f100
13
05-28-2002 09:32 PM
