Stronger axles
Axles are well covered here. For 2017, most models received completely new axles.
All gas trucks, except maybe the 350 dually, keep the exact same Sterling 10.5 axle as before.
Base F250 diesels keep the Sterling 10.5 as well.
F250 diesels with the HD tow package and all diesel single wheel F350 trucks get a new Dana M275 axle.
F350 dually diesel trucks get a new Dana M300 axle.
F450 trucks get an uprated version of the new Dana M300.
All of the "new" Dana axles have larger axle tubes, larger spline diameters and more splines, and larger ring gears.
The F450 I ordered, as near as I can tell, gets basically the same axle.
2016 --> 2017
Dana S111 --> Dana M300
Ring gear: 11.8" --> 11.8"
Axle size minor: 1.72" --> 1.72"
Axle size major: 1.85" --> 1.85"
Max rating @ ground 12,000# --> 12,000#
Tube diameter: 4.25"x4.25" --> 4.25"x4.25"
Splines: 34 --> 34
Either axle is more than big enough though.
Sources:
2017: https://www.fleet.ford.com/truckbbas...bs_-_Specs.pdf
2016: https://www.fleet.ford.com/truckbbas...SB_Updates.pdf
With the specs on the axles being identical, I'm suspicious that the 2017 specs may not be correct. Tube diameter of 4.25"x4.25" makes sense for the S111 square tubes, but not for the M300 round tubes.
Visually, the s111 looks a lot bigger.
2016 --> 2017
Splines: 34 --> 34
Sources:
The S111 may very well be bigger. A circle with a diameter of 4.25" will fit inside a square that is 4.25" x 4.25".
However, that doesn't mean it's stronger. Circles/radii/arches are the strongest designs. Designs with flat spots and hard corners are inherently weaker, because they can't distribute a point load as evenly.
It's perfectly feasible that the new circular axle tubes are stronger than previous designs, and that's before factoring in variations in wall thickness or metallurgy.
2016 --> 2017
Splines: 34 --> 34
Sources:
2016 --> 2017
Splines: 34 --> 34
Sources:
Specs are on the second line of this chart.
Correction on my original response. The C&C specs are the same on the Ford site for the 2016 / 2017 rear (although possible wrong).
The F350 SRW & DRW did get a larger ring gear, axle tubes, and axles 2017. The brakes are also larger on the 2017 trucks. Ford doesn't have the specs for the 2016 F450 rear axle on their site - the columns aren't filled out.
Again, I'm sure the rear is more than strong enough for anything I'll every throw at it.
The 350 dually and 450 share an axle for 2017. However, the 450 has larger diameter half shafts and a larger ring gear.
