~~ 1998 7.3L van with a '97 engine won't start (PCM error Ohms to Injectors Checked) ~~
Old 03-18-2017, 11:24 AM
deshet1980's Avatar
deshet1980
deshet1980 is offline
My OBD port works I am able to use my AE scanner
The PCM and IDM are from another working 1998 7.3 Van that I own.
The all of the fuses in the power distribution panel under the hood are the same.
I will check the fuses in the cab also.
Old 03-26-2017, 09:55 AM
deshet1980's Avatar
deshet1980
Is there a guide to testing the connections between the PCM and IDM with a volt meter? No Smoke and no buzz two new group 31 batteries connected. Will crank and run on either but won't run on its on power.
Thanks
motojoe35
05-28-2019 07:07 AM
Powerßroke
09-27-2017 09:11 AM
Norton72
05-17-2009 07:33 AM
stew7.3
01-16-2009 05:29 PM
BanksPSD
05-19-2008 02:17 PM
Quick Reply: ~~ 1998 7.3L van with a '97 engine won't start (PCM error Ohms to Injectors Checked) ~~
