Just be patient, Like schoo says PB blaster , maybe wiggle it often to get PB to get into it.
maybe warm area with heat gun but not too warm! Hey schoo what year jag IFS? Did you install it? I have the same 49 F! 302 AOD. Sorry to jump on thread. Let us know what worked.
i used the last year of the series 111 1987 xj6 this thing had 28 black widows
Paid $425.00
No black widows 28 not counting baby's their was a hatch, try taking a car apart every time you reach inside a black hole and find that snappy web
Sorry bokker for the hi jac
The Prep & Etch is not as friendly to your skin as Evaporust but works a lot faster. Take your time and clean it as well as possible. Wire brush it and if still seized after a rust remover soak apply more penetrating oil. You can heat it and let it cool also. It could twist off if you try to turn it while red hot.
Be patient and try your best not to break it. They are repairable but, it gets expensive.
Hi, thanks for the great response so it looks like patience and loads of freeing oil. Sorry but here in the U.K we have different oil etc. Spares are near none existent so more care on my part.
Thanks bokker.
