Third Brake Light wire
But thinking this morning hooking the brake light from the topper will not work, it will cause it to flash when you use your turn signal for that side. As far as making the truck think a trailer is there I dont think LED's have enough resistance to do that, I believe it need to detect brake resistance. I will be able to test this a soon as I run that red wire to the battery.
If you're OK with that, you could make or buy some kind of AND gate which would make the light work as a brake light unless the hazards are on. I am idly hunting for a CHMSL wire, but if I don't find one, I'll do something similar, as I want to separate the brake lights from the turn signals on my flatbed.
https://www.etrailer.com/Accessories...rt/C56196.html < something like that.
This thread is about how a topper was installed using the brake light wire from the trailer plug, using an adapter on the back of the trailer electrical connector plug.
https://www.ford-trucks.com/forums/1...installed.html
I found a brake control wire on the passenger side kick pnl with the pto wires. Violet wire cbp04 is the tag. I got the extra bed light wire from a connector buy the passenger doors mounted on the outside of the frame. I tried a 1/4 w led at the trailer plug for the brake but the truck saw it as a trailer connected.
72Blazerod
08-07-2013 04:32 PM
sleepysal
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-12-2003 07:07 PM
