No turn or brake light on driver rear
Got thr headlamp issue fixed now it seems i have a rear lamp issue. I have a running lamp in the driver rear brake lamp assembly. However, neither the turn nor brake portion function. Replaced with a new socket and bulb. Still no dice. All other lights are functioning as designed. Are these two items on individual circuits per side light the high and low beams are per side? At a loss right now.
You checked fuse #20 under the hood fuse box and it was good ?
There is no single fuse that can cause one of the rear corner signals to not work. There isn't even an F20 in the under hood fusebox.
The problem is either the multi-function switch or the wiring from the MFS to the left rear corner. Nothing else can cause the described set of symptoms.
Sorry, I didn't see a 2001 Expedition listed in your trove of vehicles, so I'll post the page from my old long gone 2001 Expedition's Owners Manual showing the #20 fuse protecting the left rear stop lamp circuit ....
You'd better go back and re-read the description for F20 that you used in an attempt to justify your incorrect response and match it up to the OP's symptom
The signal comes out of the MFS on a light green/orange wire. Gain access to to and check it with a test lamp or meter before taking anything else apart. If there's no evidence of a signal there and also no evidence of a pushed, pulled, corroded, burned or otherwise damaged pin, replace the MFS.
If the signal was present there, you'll have to check the wiring harness going to the left rear of the truck. Start with the column if you have tilt steering. There's a connector that can get stretched with the wheel is tilted down.
Ironically, I noticed an error in the factory service manual in that it doesn't show fuses #19 & 20 which would be installed in vehicles with a specific option (probably most of them). I'll have to file that missing data in my errata file.
Now I gotta go rest my head
I don't think Mother Ford bo-booed the wiring diagram. Double check me here.
It wouldn't be the first time I've found errors and omissions in Ford's documentation...
Sorry i have yet to be able to reply. I am venturing to the fuse idea. Have yet to get to it as it is a co-workers vehicle and not my own. When chasing the headlamp issue I specifically remember checking the MFS connectors. 2 wires had come a little loose and I reseated them. At that time the only issue was the low beams and fog lamps being inop which ended up being the jumpered connector in thr dash by the passenger airbag. Upon putting everything together I can remeber functioning turn signals on both sides as I checked operation before putting it all back together. Will likely check the fuse tomorrow and report back.
franklee86
06-17-2012 09:23 AM
Red9000
Electrical Systems/Wiring
03-13-2005 04:57 PM
