Steering wheel removal question
I want to remove my steering wheel from the column so I can repair it in the warm comfort of my home this winter. Any tips on getting it off? I assume I need to put a puller on it and it will come right off? Also, I know I have read some advise on epoxy and repair of the steering wheel. Any good links that will lead me right to those posts? Thanks in advance and stay warm my friends!
I mushroomed the end of the column as well. Put the nut on their so the puller doesn't do that. What a pain.
Here is my thread on my mushroom job
https://www.ford-trucks.com/forums/1...l#post13487409
Here is one picture in my thread. It looks like I bounced around a lot during that portion of my build.
https://www.ford-trucks.com/forums/1...l#post13776214
Here is the before and after:
https://www.ford-trucks.com/forums/1...l#post14100690
I used JB Weld
I used JB Weld
Get you a lisle 45000 or similar puller. As others have said, back the nut off a couple turns use the puller to pop the wheel free. Then remove the steering wheel nut last.
Steering Wheel Puller -- Lisle 45000 | eBay
Not if you leave the nut on. Loosen the nut a couple turns, put a socket on top of the nut to use as a spacer. Then you not pushing against the steering shaft and taking a chance of mushrooming the shaft.
FrankensteinFord
16
04-27-2018 09:29 AM
stavovy
09-17-2013 07:20 PM
hellbound_redneck
01-21-2009 12:52 AM
