Ontario Chapter Join Chapter>, Leader: loudfords
Ontarios 2017 January to December thread
  #31
Old 01-03-2017, 11:44 AM
Sparky83's Avatar
Sparky83
Sparky83 is offline
Originally Posted by GIGGER
Too much new years celebrating Shawn??
nahh my ice cream says its Naturally Artificial Flavored... how is something Artificial considered natural??
  #32
Old 01-03-2017, 05:48 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,108 Likes on 2,642 Posts
Good evening Gerry ,Shawn and everyone..
  #33
Old 01-03-2017, 08:59 PM
Jigger2020's Avatar
Jigger2020
Jigger2020 is offline
Received 5,128 Likes on 1,681 Posts
Thats rough Shawn, you better lawyer up , your ice dream has been hacked
  #34
Old 01-04-2017, 07:27 AM
GLR's Avatar
GLR
GLR is online now
Still smells in here......Gerry!
  #35
Old 01-04-2017, 11:44 AM
Jigger2020's Avatar
Jigger2020
ure welcome George, it sure felt better
  #36
Old 01-04-2017, 07:44 PM
56panelford
Evening Gerry, picked up the trans filter and modulator today, not sure what the gasket material is but it's grey in color and looks almost like felt. Would this need some type of sealant or go on dry..?
  #37
Old 01-04-2017, 09:24 PM
Jigger2020's Avatar
Jigger2020
Dry, is is stiff/firm when you pick it up?? does it hold its shape??
or is it floppy like a cork gasket
  #38
Old 01-04-2017, 09:30 PM
56panelford
It kind of looks like cork or fiber, dark grey on one side and light grey on the other.
  #39
Old 01-04-2017, 09:36 PM
56panelford
Made by ATP automotive, say ATP 3rd hand pan gasket. Does it matter if I change all this before running it, does it have to be hot when drained. My wife was reading somewhere that it should be at operating temp when draining the oil, I was wondering. This thing hasn't ran in about 16 years..
  #40
Old 01-05-2017, 06:26 AM
Jigger2020's Avatar
Jigger2020
In this case you might as well change the fluid 1st, but she's right
trans fluid is thin so it will run out easy,
after you clean the case & the pan good just put the gasket on dry & snug the bolts
make sure you add at least 4 liters of fluid before you start the motor,
then let it idle in Park, add fluid til its full on the dipstick ....
road test it & then check the fluid again & check for leaks, voila!
PM me your phone # & I'll call you if you wanna talk
  #41
Old 01-05-2017, 09:36 AM
56panelford
I know the oil level is up to the modulator port . I was not planning on changing this filter right away as I want to get all the body parts on first and wiring done. I have not started this engine yet but hope to within the next couple months, maybe I should wait to change the filter then.
  #42
Old 01-05-2017, 10:01 AM
Jigger2020's Avatar
Jigger2020
The trans fluid is probably low now so just check the level before you start the engine
then with it idling in Park be ready to top up the fluid so it doesnt starve the pump
when yer ready I'll be here chum
  #43
Old 01-05-2017, 11:33 AM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,074 Likes on 976 Posts
Howdy Gerry and John...happy 2017!
  #44
Old 01-05-2017, 11:36 AM
Jigger2020's Avatar
Jigger2020
Hey Bud, yer a long ways from home son
  #45
Old 01-05-2017, 12:01 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
__mm_(o.o)_mm__ i see canadians in here...
Quick Reply: Ontarios 2017 January to December thread
