2012 F250 No Radio Display
I've got a 2012 F250 XLT with AM/FM/CD/AUX radio, and the display is not working. The radio functions fine, as do all other electronics on the truck, but the display is dark. I've tried pulling Fuse #29 in the passenger kick panel, and it looked fine. Any other ideas or is my radio toast?
Thanks,
Doug
Thanks,
Doug
I had a 2014 F150 Lariat that did the same thing every once in awhile. It would not light up from a start but I could listen to it. I would shut the truck OFF - wait a few seconds and restart it. The radio ALWAYS came back ON. I figured it was one of those goofy gremlins in the truck. Only kept the F150 for a little while. Needed a bigger truck for towing the boats we work on.
same here on 2011.
if you press the screen with your thumb it will light up for a few seconds (or more) to set stations etc.
I've read here that you can touch up the solder connections in the radio. I'm planning to do an upgrade anyway to a big screen when i get around to it
The following users liked this post:
redranger1
05-26-2013 08:20 PM
