Check Engine Light Rough Running
Recently the CEL has been coming on after the truck starts and runs for about 5 seconds. It runs fine until the light comes on. Truck has no power, gets terrible mileage and runs like it is out of time.
The IPR has been cleaned with the last year. I swapped the CPS as well as the ICP. This did not cure it. The truck runs the same when the connection is pulled off of the ICP and with any one of the UVC plugs pulled.
I am having some software issues with the Auto Engenuity Scan tool. I cant pull codes or run any live stream data on it yet. Hopefully , this will be ready soon.
Any thoughts or suggestions would be greatly appreciated!
Is this what I am looking for?
More Information for DORMAN 904201
Also, the specs say it controls 4 injectors and I was thinking they only control 2?
I'm having difficulty getting autoenginuity to connect to the truck. I finally got to pull codes off of it. The scanner seems as though it will not communicate with the truck even though it says it's connected and initiated. Eventually I did get it to give me a set of trouble codes. However Kama it will not respond when I try to get live data.
