Plumbers Advice Requested
Well guys I need help and the knowledge of any plumbers in the house or guys who know their way around a oil ( boiler ) furnace.
It's 30 mins. past the witching hour here in frosty Ct. and I had to shut down my furnace at 10pm because the over pressure valve blew and the furnace is just pumping water out of my overflow pipe into my sump when its running.
How much do you think I'm looking at to have the tank and valve replaced if that is indeed the problem?
The Furnace is a Smith Cast Iron Boiler. The Expansion tank is an Amtrol Extrol 12 PSI pre load and 100 PSI max. pressure 240 deg. max. temp.
Here's some pics.
Here's some pics.
I believe so. The furnace pumps water out of the pressure valve as soon as I flip the switch. The pressure release valve is open constantly. I remember the guy at the plumbing supply company telling me that if that happened then the expansion tank is probably bad.
Received 3,102 Likes
on
78bigunns
34
10-28-2005 08:04 AM
mike L
50
02-04-2005 08:05 PM
