My Never Ending Build!
That is correct, the bumpers are fusion bumpers and I built the tire carrier and added it to the bumper. As far as the optima's, I really wanted to go with Northstar batteries but I got an amazing deal on the Optimas. I am adding two additional batteries because I am adding a power inverter, have a ton of lights, and other electronic equipment. I wanted the battery system done before I added my winch also.
The seat unbolts from the bracket with 4 bolts. I used two of the bolt locations and drilled two more bolt holes in the bracket. I then used grade 8 bolts and large washers to bolt it to the frame. The box is very sturdy and does not move at all. This is also a steel box not an aluminum. I would advise against an aluminum box just incase you were involved in a crash. I will try to get some pics of the lock that I built to keep someone from removing the whole box. I think that if it can hold people securely in the seat during a crash it can hold my box just fine. I am working to add a couple lift struts to the box so the lid stays up when you are trying to dig around in it. The box is 48 inches wide and perfect height for the second row seats.
I'm looking at hanging a pair of Group 31s underneath, just outside the frame rails... Either driver's or passenger's side.
Finally got around to working on the Ex again. After much consideration I mounted my batteries in the truck box inside my vehicle. There were a couple factors to this. 1. I wanted them close as possible to my power inverter. 2. I didn't want them exposed to the elements. 3. Hung down too low when considering mounting them to the truck frame. Here are some pics for you guys!
Left some room to route wires along the left side
these are the biggest batteries that Optima made. I got a killer deal on them is why I didnt go with a different brand.
Looking clean and protected.
This middle area will house my power inverter and my shore power battery charger. I am going to then cover the batteries and converter with a sheet of aluminum to protect them. Thermal controlled fans will keep the box cool.
Looked into the L/N 230 amp alternator? I believe they come in black too.
Leece Neville 230 amp alternator
Cable upgrade is looking good.
