1988 c6 not shifting...
I have a1988 f350 7.5 with a c6 that I recently changed the filter/fluid/filter and fluid as the old fluid was getting dirty and milky.
i ran fine last week and today, I can't get it to shift into any gears as it just sits there. No tranny noise or anything.
I had someone else move the shifter between gears and everything appears to be moving properly underneath.
It did this a month ago, and then worked.
Also, the kickdown lever at throttle body is stretched out I think.
Could I have water in the torque converter or something?
As the tranny isn't growling or anything and full on fluid.
After I changed the fluid it ran fine for the couple days I drove it though.
i think to begin with it had to much fluid, as I thought the pan was leaking originally but then noticed it was coming from the vent.
But got to thinking that since it sat all summer(periodically starting it), the modulator valve maybe go bad? The vacuum hose is oily and it's probably the original one on the tranny and I did find a bad vacuum hose right by the fitting on the back of the motor.
The truck in question is also a 4x4. And I noticed that when I move the shifter through the gears it is smooth as to my 90' superduty with a e4od I alittle firmer as it hits each gear in the shifter on the column.
maybr the shift arm in the tranny?
I never did empty the drain pain with the old fluid yet so I looked and it doesn't look watery, just milky
The C6 is all mechanical/ hydraulic in operation. My C6 has firm shifts. If there is nothing then there has been a failure in the system. As mentioned the fluid should not have been milky. I'd be concerned about the water (or coolant) in there which is probably why it was overfilled. Was there anything debris in the pan?
7Ford6
08-07-2010 12:32 AM
lslkelton
16
07-01-2004 10:41 PM
PAUL_2
07-13-2000 07:45 AM
