Brake Problems
Brake Problems
1978 F-150 4x4
Has been sitting for a few years now, just got it back up and running. My problem now is the front brakes are locking up. If you drive it for a short distance, the brakes slowly as they heat up become more locked until eventually the truck just stops. Then at this time I get out and crack the bleed bolt on both front calipers. Then its good again for another short distance. Calipers have been rebuilt. I'm thinking master cylinder and or brake booster? anyone had similar problems and what seemed to work?? Thanks
1978 F-150 4x4
... etc ... front brakes are locking up. If you drive it for a short distance, the brakes slowly as they heat up become more locked until eventually the truck just stops. Then at this time I get out and crack the bleed bolt on both front calipers. Then its good again for another short distance. ... etc ...
Are both sides getting hot? Might be the single line from axle to frame.
Just a thought! Good luck.
I've had the rubber hose to the caliper on a GM car develop a crack in the rubber, yet still not leak. But it did the check-valve thing, keeping the brake clamping even after the pedal was lifted.
Lots more pressure when the pedal is pushed down, than when it's lifted.
The only brake hose problem I've seen on Fords has been on the Tempo and Topaz front calipers. On those, the retaining bracket (which bolts to the strut or whatever, and is bent so as to curl around the hose, retaining it and tethering it out of harm's way) will end up pinching the hose, and keeping the front brakes dragging. Dunno if that's from the hose swelling, or the bracket swelling due to built-up corrosion, but simply using a flat blade screwdriver to spread the bracket where it curls around the hose, is a free and easy and effective fix for this phenomenon - I've fixed three of those cars that way...
First thing l did was unhook booster to make sure that wasnt it.
Next l undid the MC from booster when the brakes were stuck and none of the above worked so l was positive it was the MC.
dyingtolive
07-29-2011 06:24 PM
timothy47129
13
07-10-2006 04:20 PM
Native Gearhead
07-02-2003 08:44 AM
