Not sure if this is normal or not or if I am not doing something wrong. The only time my high idle kicks in is when I use the auto start. If I start with the key the truck just idles normal. The temps are cold, 20 degrees or less. This is on a 2015. Any Ideas?
Dave
Is this just based on the sound of the engine as the rpm gauge won't be functional during remote start? From some testing I did when my truck was new I recorded 950 rpm with 18 degree ambient temps, 950 at 12 and 1200 at 5. This data and more is available in the rapid heat link in my signature. I also tested the difference in engine temp when using the block heater.
