Oil in Coolant 360 FE
If all I saw or knew about your motor was the pics of the valve cover and rockers I might think it's running too cool to drive off moisture. I couldn't see a PCV valve on your pic of the engine that would help keep the oil dry. Have you pressure tested your coolant system?
If it turns out you have no leaks then at the least, those poor rockers and valve covers need cleaned.
Edit: After a little thought, finding your leak is kinda academic at this point. That poor engine probably should be disassembled, cleaned, inspected, etc.
sidewndr46
1997 - 2003 F150
10-05-2020 07:35 AM
Nobodyhearsyou
15
11-23-2016 05:47 PM
gtex
32
04-08-2006 09:16 PM
