2016 antenna replacement
I just got a 2016 F150 Sport and after adjusting the garage door to go up an extra 2 inches to get the truck in, my antenna drags across the door on the way in. I am just assuming that that will evidently damage it and break it off. I got a shorter antenna but can not get the factory one off. I am hoping that someone has run into the same issue and can give some advice on hoe to get the antenna off.
Thank you
Bill
Thank you
Bill
Most of the antena bases are a 6mm, i am not sure what the f150 is because i have not removed my antena, but there are alot of replacement antenas from walmart/autozone/advance..etc. Motorcycle shops have some real nice short rubbers that get put on to touring bikes to replace them ugly whips that come with the bikes, they work excellent. Just grab your self a shorter antena, small crescent wrench is all you need, the parts store will probably do that for yah for free. good luck.
If you go on Amazon, there are a lot of shorty antennas available. I went with this one and am very happy with it.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
