Wheel and Tire for Corvette/Flat Out Front Clips
#31
Right on! My thing is I don't like to do what everyone else has done. Widening the box would not have fixed my issue. But ya I agree. If I went any wider it would have looked strange. But the 1.75" is really suddle.
I like doing the the things that most people won't ever notice.
Seems like we have to do two of the possible three things.
1. Wider fender
2. Tubs
3. Wider box
Do any two and you have the room you need.
#32
#34
#35
ah ok. What I did before I did anything was take off the wheels from the stock suspension then put the truck on jack stands at the ride height I was looking for. Then took front and rear measurements. Then once I had things stripped down I set my ride height and rack based off of those numbers.
#36
Really? My donor didn't come with a sway bar. And none of the aftermarket replacements ones I've looked at have the dip in the middle like yours. So I guess I'll keep looking.
#38
Took a few weeks, but the crossmember is tacked in. The doner rack is not in good shape. Don't know what the PO did to it eactly, or if it was that way when it got it. But anyhow.
Next is to notch for the rack. I want to throw on the control arms and spindles to make sure I see where the notches exactly go.
However, I see that the leaf spring is still in my clip. Seem like removing it is pretty doable using a jack if it is still in a car. But mine is sitting on the floor. How do you safely removing the spring in this situation?
#40
on
My PO installed my front end and it uses coilovers . If you are using the control arms there should be no pressure on the spring once they're removed , but you will certainly have to jack it up to see and I'm sure to remove it . Sorry I'm not of more help but someone should have the answer .
#41
#45
