How difficult to set door glass?
I need to put in some new glass on my '50 F1 doors and was wondering how hard is it to do?
I assume it needs to be correct left to right in the regulator, but how do I figure what "correct" is?
What is used to secure the glass once it is set?
Thanks.
Dan Sokol
Thanks.
Dan Sokol
This image should give you a reference as to where to put the glass in the channel. I used a moving blanket folded over several times as a surface, with the top end of the glass down. Then I folded the setting tape over the bottom of the glass and used a rubber hammer to tap the channel over the tape and glass. I had a friend assist with holding the glass steady so my hands were free for the hammer and channel alignment.
Kecky
05-31-2013 06:59 PM
Aus56
09-09-2012 03:38 PM
rla337
05-06-2008 05:01 PM
mikecroskrey
09-17-2002 07:46 PM
