06 F150 speed sensor issue - Ford Truck Enthusiasts Forums
Old 12-09-2016, 09:53 PM
Anthony-Walter Anthony-Walter is offline
Anthony-Walter is starting off with a positive reputation.
hi all, i have a 06 F150 5.4l. my programmer decided it would be cool to delete my ECU. so i towed it to my local dealership and had it reprogrammed to factory specs. so at the dealership they found that the engine is throwing the P0500 code. which is saying there is an issue with the speed sensor. so first think i did was check the voltage to the sensor. at the plug im getting 11.68 volts, so i replaced the sensor and the new sensor is reading at 6.42 Ohms. before all this I should state that my gauge cluster would act up at times. such as randomly sweep the gauges while driving, everything drop to zero, etc. any help would be greatly appreciated. i tried everything i could find in the threads already
Speedo/VSS/P0528/P0500 HELP Devilmanak 1999 to 2016 Super Duty 11 02-07-2017 01:00 AM
Hope this may help someone in the future Skydivelout 1999 - 2003 7.3L Power Stroke Diesel 3 04-01-2016 09:42 AM
2004 F-250 Transmission Fluid Temp Sensor Phillip Vega 6.0L Power Stroke Diesel 10 06-01-2015 04:23 PM
What in the rear end will cause the speed sensor to act crazy junkyardjeff 1987 - 1996 F150 & Larger F-Series Trucks 4 05-30-2015 09:24 PM
backup sensor and light problems catman700 2004 - 2008 F150 8 05-19-2008 10:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
