93 F150 can't pull a load.
Old 12-09-2016, 06:38 PM
biker art's Avatar
biker art
biker art is offline
I'm still having trouble with my F150 with the 5.0 engine pulling a lite load. It has 214000 miles and runs great up to 80+ mph but if I'm pulling even a lite load up hill (4% grade) it starts to shake and lose power to where I'm only able to run at 40 MPH under WOT. Cat has been removed and new muffler and pipes installed. Helped a very little. Burn a little oil like 1 quart in 1200 miles. Maybe valve job needed? Goes through coolant like crazy. 1 quart every 300 miles. No leaks,new rad. an hoses. Exhaust is smokeless. I'm stumped.
Old 12-09-2016, 06:43 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
The shake is possible mis-fire. Mis-fire is often bad plugs or wires. How long since a tuneup? How long since fuel filter change? Start with the simple stuff. Find the coolant leak. Possible internal leak.
Old 12-09-2016, 09:01 PM
biker art's Avatar
biker art
Full tune up done one year ago with fuel filter. Fuel pump pressure is good,new wires,dist,cap all done. That's my problem. All the work done and still missing and loss of power. I had a 13' travel trailer I rebuilt but sold after pulling it 30 miles and couldn't go faster than 40 mph up a 3% grade. Very frustrating. Normal driving around town it's great.
Conanski's Avatar
Conanski
Conanski is online now
There is the smoking gun.
Old 12-09-2016, 09:04 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
x2 ... start with a compression check.
Old 12-09-2016, 09:05 PM
biker art's Avatar
biker art
Oil is clean no drips and no smell of gas in radiator.
Old 12-09-2016, 09:32 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Do a leak down test and check for bubbles in the radiator.
Old 12-10-2016, 08:39 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
Look for visual signs of head gasket leak, it's pretty easy to detect.
You can test coolant for hydrocarbons, but it doesn't have to blow into the radiator in order to suck coolant, especially if the majority of the coolant seepage happens after shutdown.
Super Duty Mike
1999 to 2016 Super Duty
03-23-2012 07:35 PM
378wby
Modular V10 (6.8l)
07-24-2011 01:07 PM
psyverson
03-17-2011 11:11 AM
ckal704
08-24-2009 05:08 AM
Americun
10-10-2006 09:21 AM
Quick Reply: 93 F150 can't pull a load.
