Dealer Inspection Findings
When I bought it last week, I did not have any inspection done. Figured, I'd spend a few $$ now to have it inspected. So, I had the local Ford dealer go over the truck this morning - sort of a pre-purchase inspection - and tell me the condition. Here's what they came up with.
1. Serpentine belt weathered - If and when coolant is drained at some point, replacement is suggested.
2. Rear rotors worn/hardened - Suggest replacement with next pad change.
3. Front brake Pads - LF worn more than RF.
4. Rear Differential cover - oil drip; might need replacement, suggest ford aluminum cover as it may be cheaper
5. Front differential cover - oil drip, may need to be cleaned and resealed/reseated.
6. Trans pan - oil drip. Possible tail shaft as well, but might be blow back from driving
7. Some oil leaks in engine valley - Intake tube replacement to start.
8. Sway bar bushings worn - rattles/clunks over bumps; Suspension components are tight - ball joints, tie rods, steering box
9. Coolant - Not Ford Coolant
10. Slight leak from front of AC compressor, seen on pulley clutch
11. Batteries - Good.
12. Alternator Charging at 14.34v
His comments were - This 16 year old 'tank' looks very good for its age and miles. The oil drips are due to age and they are not gushing leaks to cause too much worry. Just needs some regular TLC. His priority was front pads at the earliest. Rest can follow. He said get all these done within the next 10-15K miles and you should have a long lasting truck.
Brakes are pretty simple to do on these trucks. If one side is worn more than the other, the caliper slide pins may need to be replaced. You can always get the rotors machined or just replace them.
The diff covers are easy and the 08+ OEM one is a great upgrade... easy to do.
Sway bar bushings are also very easy to replace and on a 4WD Ex, you have some different options... OEM, poly...
I started searching for this information after you asked. Every place seems to list the alternator output in Amps and not Volts. Guess the tech must've measured something else and written down the note incorrectly
If that is all a dealership can complain about, looks like you bought a truck that is in great condition.
Other than the possible oil leak(s?) in the valley, all pretty easy DIY maintenance work. Cleaning up the valley may also be no biggie.
Great advice on the dual alternator style radiator hose. I've got one here on the shelf, just waiting for the next time I have to drain some coolant. No idea what was thinking, running the hose through the center of the belt.
Stewart
cityjack
03-01-2017 12:17 AM
