Sea master engines - Ford Truck Enthusiasts Forums
Sea master engines
Old 12-09-2016, 01:31 PM
Jim534 Jim534 is offline
Jim534 is starting off with a positive reputation.
Sea master engines
We have a boat with two 534 Seamaster engines installed in 1972. They now have 2800 hours on them and still run great. They're rated at 277 hp and have a torque of 492 at 2000 rpm. Only problem: they sure guzzle gas.
Old 12-09-2016, 01:42 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Well then I guess they should be called Sea Monster engines!
Is one of them counter-rotating?
What kind of carburetors do they have? Governed Holleys, like the trucks?
Old 12-09-2016, 04:59 PM
Yes, one is counter rotating. They did have the Holleys but I had trouble getting kits to rebuild them so I bought 2 Edelbrock marine Carboraters. Therefore, can't use the governor linkage but still use the tachometer and that works fine. Did have trouble with the reverse rotation engine when a broken valve chewed up the head pretty bad but not the piston. I Got parts at a local junk yard for the repairs from an updated 534 engine. Updated parts included intake manifold, cylinder heads, distributor and water pump. I was told by a Ford dealer that the update was prompted by pollution standards in 1976 in CA. The new design supposedly makes it breathe better but I can't tell the difference. I would like to find parts to update the other engine but so far hard to find. Thanks for your comments.
Engine specs Jim534 401, 477, & 534 SD Engines 2 02-01-2017 10:21 AM
534 Rotating assembly Nolan Harris 401, 477, & 534 SD Engines 27 10-04-2016 12:05 AM
Was the 534 able to hold it's own? 62FE4x4 Large Truck 11 06-30-2016 03:02 PM
what will interchange with 534 cfd590 401, 477, & 534 SD Engines 3 02-23-2016 06:32 PM
Bore Spacing And Crank Dimensions For 477/534 baddad457 401, 477, & 534 SD Engines 4 09-25-2004 07:59 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
