Engine specs - Ford Truck Enthusiasts Forums
Engine specs
Old 12-09-2016, 10:29 AM
Jim534 Jim534 is offline
Jim534 is starting off with a positive reputation.
Engine specs
I have a 1968 Ford shop manual covering the 401, 477 and the 534 giving the specifications for a rebuild of these engines. Willing to share info from manual.
Old 01-31-2017, 05:09 PM
PERFORMANCECONCEPTS PERFORMANCECONCEPTS is offline
PERFORMANCECONCEPTS is starting off with a positive reputation.
Im looking for the crankshaft and camshaft specifications for the 534. Would you be able to share those with me?
Old 02-01-2017, 10:21 AM
Specifications
Yes. The manual I have is the 1968 shop manual which has the specifications I think you're looking for. There are about 3 pages of specs for those two items. Probably too much to list here. I believe the specs are the same for the entire series. I can copy the pages and mail them to you. You can call me with your address if you'd like. 508-954-3449 if your project doesn't work out for you and the engine is newer than 1976, I'd be interested in it for parts. But in either case, you're more than welcome to the information you're looking for. I do have a cam and crank shaft which are still in the engine but I'm not sure of the condition.
Sea master engines Jim534 401, 477, & 534 SD Engines 2 12-09-2016 04:59 PM
what will interchange with 534 cfd590 401, 477, & 534 SD Engines 3 02-23-2016 06:32 PM
Need Dipstick Tube for 534 Industrial Engine crhaney 401, 477, & 534 SD Engines 0 04-15-2011 03:00 PM
4 speed gear ratios? gary534 1967 - 1972 F-100 & Larger F-Series Trucks 2 10-18-2005 12:54 PM
Bore Spacing And Crank Dimensions For 477/534 baddad457 401, 477, & 534 SD Engines 4 09-25-2004 07:59 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
