ZF 6 speed
03-23-2017, 08:47 PM
on
Dive shafts are not a problem, but dang I hate to have to start looking for a 7.3 zf6 transfer case.
Like to never found the transmission.
I wonder if you can just buy the correct input shaft?
03-23-2017, 09:36 PM
Where are you? I just saw 6.0 ZF6 with the tcase today for $1800.
03-24-2017, 07:50 AM
I am only putting a ZF6 in for the power rating compared to zf5.
I will be running a 5-600hp DT360
03-24-2017, 08:08 AM
on
Is that the plan for your f superduty build?
03-25-2017, 06:48 AM
Quote:
Originally Posted by
coreylasalle
No. My F-superduty will loose the s42 zf and get a s47
my 86 is loosing the 6.9/4 speed and getting the DT360 and the ZF6
03-25-2017, 09:34 AM
Diesel_Brad
Brad are you posting build photos of the 86?
03-26-2017, 06:52 AM
nateairman
Nothing to see other than the truck and all the parts sitting in a shed
03-27-2017, 07:58 AM
on
Well the guy I got one of my 6 speeds from had the transfer case too, so I ended up with the case that went with the transmission.
Only problem is, It's a electric shift and I don't wont that. I want to have the floor shift same as what's in the truck now.
How hard is it to swap back to the manual 4x4 shifter assy?
03-27-2017, 09:17 AM
03-27-2017, 12:05 PM
on
I will look at both cases and figure out the lever, sounds like it wont be too much problem.
03-28-2017, 02:39 PM
They are actually 2 different cases. One for electric(NV273) one for manual NV271
hillbillyk
Large Truck
01-07-2018 08:43 PM
white 66
1947 and Older Ford Trucks
04-05-2016 08:54 PM
urban87_cowboy
23
01-12-2013 06:48 AM
fixnair
10-02-2009 04:30 AM
1949f1
11-06-2005 10:37 PM
