Blend door vacum line repair
Old 12-08-2016, 05:53 PM
IcutMetl's Avatar
IcutMetl
IcutMetl is offline
Hello everyone,
While under the hood of my truck tonight for an un-related purpose; I noticed that a white vacuum line leading to what I believe is the blend door actuator, has rotted apart in one area. I need to repair or replace it. I'm just pleased I noticed it before being on the road somewhere this winter and realizing that the thing wasn't working.
It appears to enter the actuator thru a 90deg rubber nipple, and enter the vehicle along with what looks to be other vacuum lines and wires thru a rubber grommet.
I haven't made it to the parts store yet to look at my options. What do you guys suggest doing?
Old 12-08-2016, 06:02 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,156 Likes on 914 Posts
Replace the entire length. Might as well get enough to do everything. The white vinyl tubing is just the first of many to go bad.
Old 12-08-2016, 06:07 PM
IcutMetl's Avatar
IcutMetl
IcutMetl is offline
I figured that would be the response. I hate cobbing stuff together anyway when I don't have to.
Is that stuff easy to find at a parts store? I've never messed with hvac systems before other than replacing a heater core in a different vehicle.
Old 12-08-2016, 06:45 PM
rla2005's Avatar
rla2005
rla2005 is offline
It's simple automotive vacuum lines. Quite a few threads here on replacing everything.
Old 12-08-2016, 08:29 PM
Frank250Tank's Avatar
Frank250Tank
Frank250Tank is offline
I repaired mine with some smaller diameter vacuum hose. I cut back the harness to expose enough remaining vacuum line and plumbed it up. Works great thus far
Old 12-09-2016, 01:29 PM
seschenburg's Avatar
seschenburg
seschenburg is offline
My 2 cents.....Windshield washer hose will work, and it's cheap. The line under the wrap is probably fine. Peel it back until you have an inch or too of good line, put your new hose over it, attach the other end to the valve, rewrap the exposed harness and you'll be good for a long time.
Old 12-09-2016, 03:18 PM
rla2005's Avatar
rla2005
rla2005 is offline
Sorry, I disagree 100% with the above theory. That vinyl tubing has been exposed to heat regardless if it is in the wrap or not as well as 20+ years of aging. Replace it all and be done with it.
diesel_dan
10-09-2018 05:26 PM
1993 ford
09-07-2017 09:26 AM
1993 ford
06-10-2017 03:55 AM
Joe9811
02-09-2014 10:05 PM
wanness
06-14-2013 12:53 AM
Quick Reply: Blend door vacum line repair
