Truck dying after warming up to temp
So I recently inherited this truck from my grandpa and it hasn't ran much in the last two years, it starts up pretty good and runs fine and right about the time it reaches correct operating temperature it dies. I have completely went to the carburetor replaced the brain box twice, replaced the coil, it has a new spark plugs, and a new fuel pump. The last time the truck was running correctly was at 1100 feet altitude and I brought it up to 5200 feet in altitude I did reject it thinking it was flooding it at idle causing it to die but I think I have the carburetor tuned pretty well right now because it runs just fine until it gets warmed up. Any advice and help is much appreciated.
1977 Ford f-250 Custom
2wd with a 400 &NP435 four speed
completely stock
Motocraft 2150 carb
completely stock
Motocraft 2150 carb
Welcome to FTE!
There are a lot of good people here, and most of them love to answer questions.
My guess would be that it's getting too much fuel and not enough air. Perhaps idle mixture or jets (if 2150's have jets?)
But don't worry - somebody will be along shortly to give better advice!
Ok ya the distributor was going to be my next part to replace. The 2150 does have jets and I jetted it from a 57 down to a 54, I recently got a vacuum gauge I need to mess with the idol screws some more but it seemed like when I screwed them in more it wouldn't even start. So as of right now when it was running before it warmed up the screws are out about 2 1/2 turns does that sound about right ?
Two tests to try when it starts to stall out
1. Look down the throat if the carburetor and press the gas, can you see a spray or jet of fuel?
2. Pull a plug wire and check for spark.
Post your results back here
if you don't see fuel on #1, its vapor lock.
If you don't see spark on #2, it's the pickup coil in the distributor.
If both tests come back good, back to the drawing board
OK #2 I have tested but it was when it was cold does it matter if it's warmed up or not? It had plenty of spark. #1 I will test it tomorrow I know when it's running and warming up everything is working good at shooting good fuel out of the Excelerator pump ports but I haven't checked it while I was trying to die it dies so fast, it'll be hard to catch it but I will hover over it tomorrow and reply back thank you for the advice.
Yup, been there, done that.
Quick check... on a 77 which should have a duraspark, disconnect the wiring connector.
Three wires, one of which is a ground (the black one). test resistance between the other two wires. Should be 600-900. Do this right after it dies.
good luck
good luck
That's an expensive way to replace the pickup coil, but the important thing is that it's works. Congratulation and Merry Christmas!
MWB323
19
04-24-2019 05:38 PM
areoseek
21
12-03-2015 12:21 PM
Bullseye72
12-08-2014 01:17 PM
Broomfieldbum
16
01-09-2011 05:01 PM
fourfoot23
09-22-2004 09:21 PM
